Aug 15th, 2024, 1:28pm
Class A/AB/C PAE (Read 1884 times)
natnoraa
Class A/AB/C PAE
Jan 27th, 2014, 10:48pm
Hi guys,
I have a question. Given a simple bias circuit of a nmos, I would like to check the PAE.
Am running Cadence Virtuoso Spectre and the result is that a simple class C PA gives me lower PAE than Class AB or even Class A? Does anyone know the reason for it?
I have already made sure the power at the 2nd, 3rd harmonics are well below -20dBm and from the PSS function, i checked on PAE and selected the fundamental frequency in which i would like to measure its PAE.
I have also used a simple LC oscillator tank to make sure i've filtered out all the harmonics leaving only the fundamental.
Any help would be appreciated. Thanks!
natnoraa
Re: Class A/AB/C PAE
Reply #1 - Jan 27th, 2014, 10:50pm
and also, Vth is about 0.55V so any biasing point below that I'm taking it as a Class C? at 0.55V it will be a class B?
natnoraa
Reply #2 - Jan 29th, 2014, 7:59am
It's okay guys. I've managed to solve this. Thanks for reading
Natnoraa
