Aug 15th, 2024, 11:24am
Pages: 1 2
How to choose Rp, L, C for cascode LNA? (Read 17955 times)
baab
EA
Re: How to choose Rp, L, C for cascode LNA?
Reply #15 - Feb 14th, 2014, 7:36pm
I think in the circuit above, Ls and Lg already form the input matching network and we don't need to make another one like L, T or Pi networks.
Is that right?
RFICDUDE
Reply #16 - Feb 16th, 2014, 5:04am
Hi Baab,
Looks like you did not recalculate or remeasure Cgs after you scaled the width from 24um to 773um to raise gm from 14mS to 442mS. Cgs is proportional to width, so Cgs will increase by a factor of 32.
baab
EA
Reply #17 - Feb 16th, 2014, 7:57am
RFICDUDE wrote on Feb 16th, 2014, 5:04am:
Hi Baab,
Thanks. However, let's me explain it a bit more.
As in the picture, first I calculated optimum Q for minimum NF.
From Q computed, the total Cgs is determined with the formula:
Cgs = 1/(Omega* Q* 50Ohms)
(Cgs here is the capacitance with minimum NF, after Cgs is calculated I need to resize the width of transistors to get the Cgs value)
And from that Cgs I can figure out the total width of transistors with the formula:
W (final W) = Cgs/(2/3 * Cox* L)
RFICDUDE
Reply #18 - Feb 16th, 2014, 11:56am
I guess what was throwing me off is that you have a very large gm for the size of the device, but I missed that you are using a fairly large bias voltage.
My misinterpretation aside ...
The transit frequency is very high and the resulting Ls is unrealistically small to implement.
I have seen papers where Cgs is intentionally made bigger without increasing transistor area by simply placing some additional fixed capacitance across Cgs. This lowers the transit frequency independent of gm and gives you a degree of freedom to use more practical values of Ls for the gate impedance match problem.
aaron_do
Reply #19 - Feb 16th, 2014, 6:03pm
Hi baab,
its been a while since I did those analyses, and I suspect they may be inaccurate for such a high gm/Cgs (Your value of Ls is too small to be practical). As I remember, the equations are based on a rather simplified transistor model.
For the impedance matching you are right, you don't need to add an additional matching network. But remember to take into account the gate resistance of the transistor, and Lg's series resistance. As RFICDUDE pointed out, you may want to lower the fT of your device which will lead to a more reasonable value of Ls.
regards,
Aaron
baab
EA
Reply #20 - Feb 17th, 2014, 12:13am
Thank you. I read about the adding of the additional capacitor. However, it makes the implement more practical. In simulation, my my circuit above should be fine, right?
To be practical, please what is the range of Ls? I just simulated NFmin with Ls swept. As Ls increases, NFmin increases significantly.
With Ls = 10um, NFmin is about 1.99dB at Vgs = 0.6V.
aaron_do
Reply #21 - Feb 17th, 2014, 6:27pm
What do you mean by Ls = 10um? As far as I know, a practical value will depend on your implementation and layout.
If you are doing using a down-bond (bondwire) as Ls, then the down-bond inductance would be roughly 0.5 nH. You would also need to take into account the layout routing from the source of the transistor to the bonding pad. This could be 0.1nH for example, but its better to model this. So the total would be roughly 0.6 nH.
If you are using an on-chip Ls, you can make Ls smaller. But you need to take into account how accurately you think you can model Ls (including parasitic inductance).
baab
EA
Reply #22 - Feb 17th, 2014, 11:58pm
Hi, Aaron.
Sorry for the mistake. I will need to look it up again. I don't remember exactly the value right now.
We have the lower limit for inductance because the parasitic inductance of bondwire, right?
aaron_do
Reply #23 - Feb 18th, 2014, 6:51pm
It depends on your design. If you reference all of your ground's to the transistor source, then the ground downbond won't have any effect. Its easier to do in a differential circuit due to the virtual ground. The short answer is "no", the bondwire inductance doesn't limit the amount of source degeneration. The lower limit is all of the parasitic inductance due to your routing.
Aaron
Pages: 1 2
