Aug 15th, 2024, 10:16am
effects of multiplier and Wf to minimum noise factor (Read 1031 times)
baab
EA
Jan 29th, 2014, 4:04am
I have just read that minimum noise factor Fmin is invariant to number of gate fingers  Nf, and number of transistors m connected in parallel, but depends on Wf.
I feel a bit confused. Wf and multiplier m play the same function, isn't it?
However, relating to noise factor, they are not the same.
Could anyone explain why?
Thanks.
