Jul 22nd, 2024, 12:38am
Pages: 1 2
Distribute bias current or bias voltages ? (Read 12291 times)
harpoon
Hampshire
Feb 11th, 2014, 2:16am
hi all,
i am designing an array of amplifiers (say 100) and need to bias all of them in the same way.
i can generate a 100 bias currents and mirror them in the amplifiers (also need to generate cascode bias voltages) or i can generate a generic bias voltage and connect it to the gates of all the current mirrors in the amplifier.
i am keen on just distributing bias voltages (including cascodes) with a high series resistor (~10k) between the various bias lines.
comments anyone ?
aaron_do
Re: Distribute bias current or bias voltages ?
Reply #1 - Feb 11th, 2014, 2:55am
Its usually recommended to distribute current as the lower impedance picks up less noise.
Aaron
harpoon
Hampshire
Reply #2 - Feb 11th, 2014, 3:27am
that is how i usually do it ... anyone in the "distributing voltages" camp ?
carlgrace
Berkeley, CA
Reply #3 - Feb 11th, 2014, 2:36pm
Aaron's right about voltage distribution being noisier but also think of crosstalk.  If you have one voltage node connecting all your amplifiers together it is much easier for them to talk to each other.
One problem with distributing voltages is that you typically end up with errors because the "grounds" are far apart and there is some finite impedance between them.
One idea is to send a single current to amplifier 1, then generate an output current to amplifier 2, and so on.  That way you are distributing currents but you don't need to route 100 wires from a master bias circuit.
Also, if you're designing an array, I highly recommend you do the layout so that it is "routed by construction".  Try your best to limit top-level routing.  It will save you time and the array will match better.
RobG
Bozeman, MT
Reply #4 - Feb 11th, 2014, 10:10pm
carlgrace wrote on Feb 11th, 2014, 2:36pm:
A couple of observations - in addition to IR drops causing problems when matching voltages, process and temperature mismatches between components are issues if the distance between the devices is large. Beware, this can also bite you if you route current to create a voltage. I know of a group that tried to create local voltage references routing a current and ran into trouble because the local resistance didn't match the master one. Temperature, process, and packaging stress all conspire to make devices different across the die.
Avoid errors caused by the conversion device: if you are trying to create a voltage then you should generally route a voltage. (You might have to Kelvin connect things to avoid IR drop problems.) On the other hand if you want to create a current (for example, by biasing the gate of a local current source) you should route a current and mirror it locally.
When you have a huge array of devices it may make sense to do a little of both - make the layout tall and skinny so the biased devices are adjacent and have them all share the same local bias. You might be able to make this work for (guessing) 10 amplifiers without the end amplifiers debiasing. This means you will need ten of these sub-blocks to get 100 amplifiers, but you will only have to route ten bias lines. As Carl pointed out, you will have to be careful that the amplifiers don't crosstalk via the common bias line.
And for giggles I'm going to make Carl regret suggesting daisy chaining 100 biases since even a 5% error in the mirror gain will cause a 13,000% error in the last one. Wink I will leave it as an exercise for the reader to calculate the random mismatch and thermal noise errors of the last device (hint, ~sqrt(200)x).   Grin
harpoon
Hampshire
Reply #5 - Feb 12th, 2014, 12:29am
thanks everyone, all good ideas and suggestions ...
i think i may do the following ...
distribute current to 20 local bias blocks, and have each of these bias blocks will distribute the bias voltages to 5 amplifiers.
the distributed voltages are going to gates only, so i won't expect voltage drops.
also, at the receiving amplifiers, I intend to put a high value resistor in series to form a simple RC filter so that any high freq noise coupled into the bias line gets attenuated.
comments anyone ?
aaron_do
Reply #6 - Feb 12th, 2014, 2:13am
Last point, which has already been touched on, but a voltage always comes with it's reference, so when you distribute a voltage, ideally you need to distribute its reference too. Although a capacitive load won't result in any DC drop along the line, there could be an AC drop. So any noise/transient could be a problem...
BTW, I'm not saying anything about the method you've chosen since it entirely depends on your design/layout.
Aaron
carlgrace
Berkeley, CA
Reply #7 - Feb 12th, 2014, 8:30am
First off, I do in fact regret suggesting you use daisy chaining.  How boneheaded!
That said your plan sounds solid.  My advisor once said "route currents globally and voltages locally" and that sounds like what you're doing.
The bias line filtering is a good idea.  Besides the resistor you can put moscaps referenced to whatever supply the transistors are referenced to in order to do more filtering.  (by just putting the resistor you're relying on the gate cap of the bias xtr which might be small).
RobG
Bozeman, MT
Reply #8 - Feb 12th, 2014, 9:33am
harpoon wrote on Feb 12th, 2014, 12:29am:
This is done all the time with good success but as aaron said, voltages come in pairs so you are also routing to the source - which is actually where the problem comes from since it is resistance in the source line that causes debiasing or worse, if signal or noise currents flow through that line the IR drop in it will modulate the gate-source voltage. This is not a reason to avoid routing a common gate voltage - just make sure you check the effects of metal resistance in the source return line because it can be unexpectedly high. Making the overdrive of the current source as large as possible will help and is always a good idea.
I've also done this - you will have a slow startup but that might not be important. Gate leakage could be important, yet it may not be modeled so check (I don't know if gate leakage would create noise problems with a large series resistance - base currents in BJTs do. Does anyone know?).
One thing I found totally counter-intuitive is that routing a small current is less noisy than routing a large current if you are filtering the resulting voltage generated (which could be either an IR or Vgs). The reason is that the AC impedance the current sees is 1/(sC) and the magnitude of the total thermal noise is less with a smaller current than with a larger current. Think about it - a current that is twice as large has sqrt(2) more noise. But I suppose if you made it too small you would run into 1/f noise and mismatch problems.
Of course, all this advice could be total overkill - it depends on your application.
And anyone familiar with Carl Grace's work knows he isn't a bonehead Smiley.
« Last Edit: Feb 12th, 2014, 11:17am by RobG »
harpoon
Hampshire
Reply #9 - Feb 13th, 2014, 4:42am
thanks everyone for participating ... really interesting ideas and approaches ...  :)
Horror Vacui
Dresden, Germany
Reply #10 - Feb 13th, 2014, 4:46am
RobG wrote on Feb 12th, 2014, 9:33am:
It was interesting to read and think about it. It is counter intuitive indeed! But it is only true if you use the same resistor to form the RC filter and convert the current to voltage. If you add an RC filter with a separate, high enough R to make the filtering pole approximately independent from the current-to-voltage converter resistor, then you get back the familiar higher signal power, higher signal-to-noise ratio.
The new, higher value resistor should not increase your noise, since it will be still kT/C. Of course it needs more area.
RobG
Bozeman, MT
Reply #11 - Feb 14th, 2014, 7:44am
Horror Vacui wrote on Feb 13th, 2014, 4:46am:
I don't quite understand your assumptions. I'll revisit this and show the math. I think mine may neglect noise below the cutoff frequency.
Horror Vacui
Dresden, Germany
Reply #12 - Feb 17th, 2014, 12:48am
Here is my simple calculation:
If we use higher current to generate the same voltage, then the resistance would be proportionally lower.
v=i*R  &  vn^2=c*i*R^2      p=1/RC
v'=2i*R/2  &  vn'^2=c*2i*(R/2)^2=c*i*R^2 /2 = vn^2 /2 --> vn'=vn/sqrt(2)      p'=1/(R/2)/C=2/RC
So in the double current case we have 1/sqrt(2) voltage noise if there is no capacitance. But if there is a cap, then the bandwidth of the RC filter increases. This results in increased noise. But if the filtering pole is independent of the current-to-voltage generating resistor, then higher current means lower noise.
Reply #13 - Feb 17th, 2014, 2:08pm
if you are going a distance distribute by currents
Voltage distribution will pick up the ground to ground voltage difference as noise.
(modulated bias circuits are the result)
Voltage distribution will suffer from distance across the die matching issues.
Yes you can locally filter a voltage bias but you can not get around the matching over distance problem. Also you start to fight the RC filter problem of setting the pole low enough in frequency while keeping the area small. Small C can lead to big thermal noise contribution to your bias circuit.
In some big current array devices, I have done a two stage bias system of multiple current bias distributions to  local reference diodes which then provided a bias point for the local devices. How big that "bias circle" was a function of the proximity matching data.
harpoon
Hampshire
Reply #14 - Feb 18th, 2014, 5:21am
loose-electron wrote on Feb 17th, 2014, 2:08pm:
i like this idea ... distribute current globallly ... and then again locally.
Pages: 1 2
