Lex
In image sensors where there can be millions of amplifiers and ADC's on several micron pitch, I've seen mostly voltage routing. The two-stage-bias-system that is mentioned, I've seen on silicon as well, thought it has the disadvantage that it can create 'block patterns' as the part of the noise is correlated. Block patterns are more visible than the smooth gradient that would normally arise. (Hence more disturbing to the eye.) Of course, it depends on the application whether this is a problem.
Another obvious thing is whether changing from voltage to current routing costs power. In the image sensor example, the extra current draw would also be quite costly.
