Jul 22nd, 2024, 12:35pm
RMSjitter contribution of chargepump to pll o/p. factor of 2 after integ or not? (Read 1550 times)
yvkrishna
Feb 13th, 2014, 1:41am
I am running pnoise simulations using spectre on chargepump.
I get a noise profile of chargepump which has flicker noise+thermal noise floor.
analytically also it should be a scaled version of  current source noise  with duty cycle of the square wave as shown in.. http://www.designers-guide.org/Forum/YaBB.pl?num=1389088736/1#1
since this is already 2 sided noise PSD ( which is in the form of 4kTgm )  I think we just need to integrate the noise psd (in the pll bandwidth) and multiply with PLL transfer function to output while estimating rms jitter.
However I have noticed many designers and journal papers using a factor of after integration.
Please clarify whether a factor of 2 is needed or not and why ?
yvkrishna
