boe
Rajdeep, inherited connection is commonly used to define which net the power/ground connections of a certain part of the hierarchy tree should connect to. This is achieved by global nets with inherit attributes: setting the associated attribute to a net propagates this net down the hierarchy to connect to all uses of this global net until overridden. Does this help? - B O E
