Jul 22nd, 2024, 8:36am
Passive adder/subractor possibility (Read 2970 times)
eternity
Feb 25th, 2014, 1:55am
        I would like to know about the ways to do the voltage addition or subraction without using an opamp.
If you know some ways, please feel free to share it here
raja.cedt
Re: Passive adder/subractor possibility
Reply #1 - Feb 25th, 2014, 7:21am
Potential divider would help for addition.
Tx,
Raj.
eternity
Reply #2 - Feb 25th, 2014, 7:33am
Thanks for the reply
i am more interested in voltage subraction than addition
potential divider will not help me with this scenario i guess
thanks
carlgrace
Berkeley, CA
Reply #3 - Feb 25th, 2014, 7:51am
You can do it with capacitors.  Charge up two caps in parallel, then put them in series.  Charge in conserved and voila!  You have an adder.  Flip some of the capacitors around before you put them in series and voila!  You have a subtractor.
Their are lots of practical problems with this technique though.  The principal issue is charge sharing with unavoidable parasitics.  This means your addition will not be accurate (and will be hard to predict).
That's why op amps are used in this type of circuit.  Virtual grounds are very nice things.
carlgrace
Berkeley, CA
Reply #4 - Feb 25th, 2014, 8:05am
