Jul 21st, 2024, 6:30am
Designing fully differential Telescopic Opamp (Read 8227 times)
aditya_12p
Mar 20th, 2014, 1:35pm
Design fully differential telescopic OPAMP(single stage only)
a) Analysis of all equations of your design, with a
systematic derivative of all transistors W/L ratios
and spectre simulation of circuit for the following
specifications.
i) Open loop gain(DC gain) ≥ 80 dB
ii) UGB ≥ 300 MHz
iii) Differential Output voltage swing ≥ 3V
technology 0.18um
Can somebody tell me procedure to bias the circuit and schematic of it. I am trying to bias the circuit but unable to understand the concept behind the calculation of W/L ratio.Can you explain?It will be appreciated if somebody does analyse and calculate W/L values.
Is it necessary to use CMFB to bias the circuit.
aaron_do
Re: Designing fully differential Telescopic Opamp
Reply #1 - Mar 20th, 2014, 6:20pm
since it is fully differential, you will need CMFB.
For the W/L ratios, note that it depends on the load. i.e. what resistance/capacitance are you trying to drive?
As a start, you can take out your circuit, and write down what you want for all of the biasing voltages. For example, suppose you have a 1.8 V supply, then you might want the output common-mode voltage to be 1.0 V, and the bias voltage of the cascode node to be 1.4 V. You also might want your gate overdrive for the PMOS current sources to be equal to 0.2 V. So you can easily write down all the node biasing voltages that you want. After that it is a simple matter of using your equations to calculate W/L. However, since you haven't defined the power consumption or the load, its all going to be relative...
One more thing, in order to get 80 dB gain, some of your lengths will probably need to be more than minimum.
regards,
Aaron
aditya_12p
Reply #2 - Mar 21st, 2014, 10:01pm
I implemented the fully differential telescopic opamp with cmfb circuit . I got a gain of 85dB voltage swing more than 3V but UGB is 80Mhz . Any ideas on how to increase the UGB of the opamp?
Power consumption should be less than 3mW and Vdd is 3.3V
aaron_do
Reply #3 - Mar 23rd, 2014, 5:53pm
its likely to be a matter of sizing/biasing point. Is your opamp driving any load?
Aaron
aditya_12p
Reply #4 - Mar 24th, 2014, 10:27am
schematic of the circuit that i used.how to decide the bias point ?
AnalogDE
Reply #5 - Mar 24th, 2014, 11:27am
Try increasing the input pair gm to push out the dominant pole.
You may need to burn more power.
aaron_do
Reply #6 - Mar 24th, 2014, 5:53pm
You seem to be avoiding the most important question...are C0 and C1 the load?
Reply #7 - Mar 26th, 2014, 11:20am
He needs some basic books and classes in the subject first.
RobG
Bozeman, MT
Reply #8 - Mar 30th, 2014, 10:02am
loose-electron wrote on Mar 26th, 2014, 11:20am:
Hell, this place would implode if everyone did that.  ;)
I don't know why books "calculate" W/L. Mostly what you need to know is that gm =~ 2I/(Vgs-Vt) in strong inversion. In weak inversion gm becomes largely independent of Vgs-Vt so maximum gm will be ~I/75mV.
This is an approximation, but now you have gm in terms of I and Vgs-Vt, which are the only physical design variables that you can change. I is limited by power, and Vgs-Vt is limited to ~150mV for the diff pair and by headroom requirements for the loads and cascodes.
UNITY GAIN Bandwidth is =gm/Cload/2pi =~ so maximum bandwidth is (I/75mV)/Cload/2pi.
From this you can determine how much current you need to achieve your desired UNITY GAIN bandwidth for a given capacitive load. If you are close you can see if you can get enough gm in weak inversion (realizing your input devices are going to get very wide and increase the input capacitance), but if you are off by a factor of two you either have to relax your power requirements and increase I, or decrease your load capacitance. You don't have any other options.
I emphasized UNITY GAIN because if you are configured for a higher gain your bandwidth will be scaled by your feedback factor.
I'm sure there is a paper or book out there that covers this way of designing but I'm not aware of it.
rg
Reply #9 - Apr 1st, 2014, 12:45pm
Implosion might be a good thing at times...
