Aug 16th, 2024, 11:43am
how can I simulate guard rings? (Read 2096 times)
dog1
Mar 21st, 2014, 6:07am
Hi guys, I am simulating an LNA at 60GHz and need some inductors there. And I need to incorporate the couplings between the inductors and other structures. However, I don't know if there is a way to incorporate the effect of the guardring in the simulation when dealing with those couplings. Right now, I mostly use momentum for the simulation of large metal structures like inductors, but the effect of the guarding ring in the substrate can not be taken into consideration there. And also in the process I uses a lower metal shielding is not recommended, thus the effect of the guarding ring is very important.
Thanks!
Re: how can I simulate guard rings?
Reply #1 - Apr 7th, 2014, 2:35pm
QRC can extract substrate connections, and can also extract inductance. There was a paper on using QRC to extract designed inductors (in addition to parasitic inductance) at CDN Live! EMEA a couple of years ago - http://www.cadence.com/pages/dh.aspx?vfile=/cdnlive/library/documents/2012/eu/CD... - you'll need a login to access this, but the site allows you to create one.
