Aug 15th, 2024, 11:18am
OPTIMIZATION TECHNIQUES FOR RF CMOS CIRCUITS (Read 2656 times)
Mir
Kashmir
Mar 30th, 2014, 8:06am
What should be an approach to achieve a low noise figure in a RF Cmos circuit while doing optimization
With Regards
aaron_do
Re: OPTIMIZATION TECHNIQUES FOR RF CMOS CIRCUITS
Reply #1 - Apr 3rd, 2014, 2:51am
Your question is way too general. So as a very general answer, I would say keep the design simple and maximize your gain. But really if you just follow that you might end up with the lowest noise circuit in the world that doesn't work properly.
Aaron
Mir
Kashmir
Reply #2 - Apr 3rd, 2014, 6:08am
thanks Mr. Aaron
Actually i had designed a Wideband Rf Mixer (2-6GHz)...though m getting gain quite high (23dB)but at the same time Noise figure is (37dB SSb)...i.e NF is such a big concern here
With Regards
aaron_do
Reply #3 - Apr 3rd, 2014, 6:31pm
That's an unusually high NF even without an LNA. Is your output frequency below the flicker noise corner? Does it match simulations? Maybe there's a problem with your circuit.
regards,
Aaron
