Jul 16th, 2024, 1:34pm
why cmos relaxation RC oscillator is frequency stable over varying temperature? (Read 4160 times)
kanz
Apr 04th, 2014, 3:29am
cmos relaxation RC oscillator was found to be frequency stable when i swept temperature ranging from -40 degree to 100 degree.when i plotted propagation delay of the cmos inverters which i used for this design,it was found to be varying with temperature sweep.Why the change in propagation delay not affecting the frequency of operation ? In the case of ring oscillator ,propagation delay is varying much and it is affecting the frequency ..what point am I missing here ? please help Sad
boe
Re: why cmos relaxation RC oscillator is frequency stable over varying temperature?
Reply #1 - Apr 7th, 2014, 5:26am
Kanz,
the frequency depends mainly on the RC time constant, I suppose...
- B O E
analog_rf
Universe
Reply #2 - Sep 22nd, 2014, 5:38am
There could be some kind of cancellation hapenning. I suppose you are using comparators, could be possible that comparators(I/C or RC kind of osc's) are slowing down at 100c and your reference current is increasing at 100c,effectively ending up compensating each other.
raja.cedt
Reply #3 - Sep 22nd, 2014, 7:13am
what's your architecture? is it based smitt-trigger and inverting amp or some capacitor charging and comparator?? I didn't understand why inverter delay comes into picture?
@analog_rf..Can you explain your reply bit more clear..Usually compactor is much faster than actual oscillator delay, so I don't think that makes lot of diff.
Raj.
analog_rf
Universe
Reply #4 - Sep 24th, 2014, 6:03am
Faster is a relative term. As the Osc frequency reaches say tens of Mhz Comparator delay begins to play a role (say 20Mhz or more).Basically if without applying any cancellation techniques, you end up getting very good freq accuracy, then you are probably seeing some cancellation (eg:comp delay more at 100c causing output freq to decrease and Iref  increasing at 100c). One method to isolate causes in such a scenario would be to plot Shockedsc freq vs Temp for atleast 5 temperature points and you would see the freq variation peaking at a point other than 100c.
