Sep 17th, 2024, 6:52pm
square law mixer simulation (Read 2945 times)
mixed_signal
Apr 07th, 2014, 8:12am
I am simulating a square law mixer and the input to it is RF+LO. What is the best way to combine RF+LO?
Use 2 ports and vcvs to add? But  this screws matching since vcvs has high Rin and low Rout. If I put 50 ohm in parallel with port then I get incorrect NF?
Put 2 ports in series? I want to simulate noise figure and matching.
aaron_do
Re: square law mixer simulation
Reply #1 - Apr 7th, 2014, 5:53pm
How do you intend to do it in the real design? Transformer? If you just want some kind of ideal simulation, then you could use a PORT for the RF input, and put a voltage source in series for the LO. But in the final design, it sounds like your LO is going to affect your input matching...
regards,
Aaron
mixed_signal
Reply #2 - Apr 9th, 2014, 8:08am
Hi Aaron,
I am using a cyclic combiner using L and C networks. If I use a voltage source then will spectreRF properly simulate large signal effects of LO since its not a port.
mixed_signal
Reply #3 - Apr 9th, 2014, 8:31am
Hi Aaron,
I am using offchip transformer to generate LO+, LO-, RF+, RF- though and a cyclic combiner afterwards. I have posted a test setup question in RF measurements section. You may have a look.
