Aug 15th, 2024, 11:22am
Receiver design (Read 3641 times)
tabascorez
Receiver design
Apr 08th, 2014, 2:07am
Hi
I need to design a receiver to meet the following specifications. Can anybody please lend me some help about the type of receiver I should use and why? The specifications are attached.
aaron_do
Re: Receiver design
Reply #1 - Apr 8th, 2014, 6:06pm
it looks like a Wifi standard. So I would suggest looking at Wifi products or papers to see what they did. Just curious though, how could you know the "image rejection" requirement without knowing the type of receiver? To me the specs look doable with a direct-conversion receiver (DCR), except for the IR which you will need to work on, but a DCR may not need such high IR anyway.
Aaron
tabascorez
Re: Receiver design
Reply #2 - Apr 8th, 2014, 7:29pm
Yes its the WLAN 802.11a standard. I am new at designing this stuff, so can you guide me how to calculate the parameters I need to set when I do the simulations?
aaron_do
Re: Receiver design
Reply #3 - Apr 8th, 2014, 8:36pm
if you have any specific questions, I'm sure somebody here can answer them. If you're trying to get an overall understanding of the specifications, its better that you read up first from texts and such.
Aaron
tabascorez
Re: Receiver design
Reply #4 - Apr 8th, 2014, 9:03pm
I have been reading in a book and the structure that they used was this type (attached). Now how do I set the different values for the LNA, LO and input to match the specs?
aaron_do
Re: Receiver design
Reply #5 - Apr 8th, 2014, 11:14pm
you want to know how to set all of the parameters? Maybe you could make a list of which parameters you need to know. It should simply be a matter of understanding cascaded NF and IIP3 equations. For these ideal components, you will probably need to match all the impedances in order to get the right gain values...
regards,
Aaron
tabascorez
Re: Receiver design
Reply #6 - Apr 8th, 2014, 11:28pm
OK let me give it a try and see what I come up with. This lead/lag is confusing me..
