Jul 18th, 2024, 12:25am
$random always generates the same value (Read 5102 times)
Lucho
Bucaramanga - Colombia
Apr 08th, 2014, 1:11pm
Hi have the following verilog-a block for a random number generator:
// VerilogA for Example, RdnGen, veriloga
`include "constants.vams"
`include "disciplines.vams"
module RdnGen(out);
output out;
electrical out;
integer randn;
integer sign;
analog begin
randn = $random %60;
sign = (randn < 0) ? 1:-1;
@(initial_step)
$strobe
("Rand\t\t",randn,
"\n", "Sign\t\t", sign,
"\n\n\n\n\n");
I don't understand why every single time I run this code the "randomly" generated number is always the same.
Any hints ?
Thank you,
View Profile WWW Lucho Lucho lucho_lazaro   IP Logged
Re: $random always generates the same value
Reply #1 - Apr 9th, 2014, 11:21pm
The seed is such that simulations are reproducible - you run the same simulation twice, you'll get the same answer.
Lucho
Reply #2 - Apr 10th, 2014, 11:20am
Thank you very much for your answer,
However, we've observed that for IC5.1 that is not the case, as for each DC op point simulation we obtain a different randomly generated number. This issue has appeared in the virtuoso 6.1.5 version.
As a secondary question, what would be an alternative then to obtain a randomly generated sign (+ or -) for a signal that would be used as a DC offset for an amplifier model ?
Lucho.
Reply #3 - Apr 16th, 2014, 10:51am
The LRM says
"The random_seed argument may take one of several forms. It may be omitted, in which case the simulator picks a seed."
It sounds like the simulator changed how it picks the seed between the different versions.
To work around this, you'll need to specify a seed, probably by passing in the trial number of the simulation.
