aaron_do
the bottom circuit is physically impossible. A capacitor will always have some resistance and energy will be burnt in it when you start the simulation. In reality there could even be some energy radiated due to the antenna formed by the loop. So the energy at the start of the simulation will be more than that at the end.
I believe that for the simulation, there is a minimum resistance attached from each node to ground, so given enough time, the voltages will eventually settle to 0 V.
regards, Aaron
