Jul 20th, 2024, 2:18pm
inverting Boost converter (Read 4197 times)
bki
Apr 17th, 2014, 2:03am
i am circuit design beginner (student) and have a little problem.
I need to design an integrated inverting boost converter that is able to generate -70V (negative voltage) at the output from 5V input supply.
The technology that i use only allows me to use NMOS transistors and the source of those transistors need to be connected to ground.
Therefore, i can not use a regular inverting Boost Converter topology, where the switch connects the input voltage to the inductor node.
Any ideas how to implement the circuit instead?
Re: inverting Boost converter
Reply #1 - Apr 22nd, 2014, 3:39pm
Are you inside an IC or on a PCB?
You can generate the V+ (say 80V with a LC boost circuit) and then use sequenced switches to take that voltage and invert it to -80V
Charge the capacitor to 80V, and then sequence switches on a holding capacitor to make it -80V, where you use a diode (needs to float from substrate) to dump it into a holding capacitor.
bki
Reply #2 - Apr 23rd, 2014, 4:53am
thanks for your message. It is for an IC.
I am not a native english speaker, therefore i donīt really understand what do you mean with sequence switches ?
Maybe do you have a picture example?
Thank a lot for your help!
Reply #3 - Apr 23rd, 2014, 3:00pm
http://www.linear.com/products/Inverting_Regulators
Take a look at the above devices, this is what you are trying to do.
bki
Reply #4 - Apr 24th, 2014, 5:39am
exactly, but i am doing it integrated. So, i can not use another IC.
My big problem is that my technology offers no PMOS transistors - only NMOS.
Reply #5 - Apr 24th, 2014, 4:25pm
you may have to create what are called "boot power" to  bias the NMOS transistors above the power supply rail to use NMOS switches only.
see:
http://4.bp.blogspot.com/-GZBCM0xlSbk/UPvnSo5w4rI/AAAAAAAAAZo/YUTt0KpFnPA/s1600/...
which shows an example of how to control an NMOS transistor to switch a large positive voltage.
