Jul 16th, 2024, 3:35pm
Load line equation (Read 755 times)
Venture
UK
Load line equation
Apr 20th, 2014, 3:39am
Hi there,
New to the forum so go easy on me!
I'm trying to find the most accurate load line equation for designing an RF power amplifier using a mosfet transistor. The device itself is MRF173 and I need 80W from 28v. So far I have seen three variations on the same theme, all which give different results.
What do you guys think?
Here are the 3 equations I've seen...
Vcc 2 / 2 x Po
Vcc - Vsat 2 / 2 x Po
Vcc x 0.85 2 / 2 x Po
I thought the middle Vsat one was from Steve Cripps and more applicable to bipolar but someone has said you can use it for a mosfet and assume 2V for Vsat.
Sorry about the presentation of the equations, the first two 2s are supposed to be 'sqaured'. I will figure out how to do it properly soon!
Thanks, Venture
aaron_do
Re: Load line equation
Reply #1 - Apr 20th, 2014, 6:14pm
if I had to pick one of the equations, it would be the second one. The third looks like the 0.85 was found by experience, and the first is missing the effect of Vsat. However, you can't just assume Vsat is 2 V, since some PAs are designed with a 1.8-V supply. In fact, I think the value of Vsat is going to depend on the linearity required by your PA since there isn't exactly a well defined clipping of the signal due to Vsat...
For a first-pass design equation, equation 2 is fine...
Aaron
Venture
UK
Reply #2 - Apr 24th, 2014, 4:40am
Hi Aaron,
Thanks for the info. I've been digging a bit since posting and it seems that  the mosfet equivalent of Vsat is VGth, so can vary like you say. For the kind of FETs i'm using it seems to vary from about 2-4V.
Many thanks.
