Jul 16th, 2024, 6:26pm
Keithley low noise source vs potentiometer bias: Noisier? (Read 3464 times)
mixed_signal
Apr 22nd, 2014, 7:19am
Hi ,
Which biasing will be more noisier?
Resistor biasing using a potentiometer (acting as current source)
External Keithley low noise source.
Since resistor is passive , it should be low noise than keithley, right?
Re: Keithley low noise source vs potentiometer bias: Noisier?
Reply #1 - Apr 22nd, 2014, 3:32pm
A current source is always noisy due to high impedance characteristics.
You want ultra low noise? Use a battery.
mixed_signal
Reply #2 - Apr 22nd, 2014, 9:36pm
Hi loose-electron,
You mean resistor for biasing source and battery for Vdd?
Reply #3 - Apr 23rd, 2014, 2:56pm
back when I was characterizing some ultra low noise things, we found that using a battery as the power source, and fixed resistor dividers with filter capacitance got it done.
Resistors/Temperature low enough in value that thermal noise did not rise up, and the capacitor such that the BW was like 0.01Hz or something similar.
We were looking at flicker noise at the time and we could actually see the transitions associated with single electrons from a CMOS amplifier. Smiley
Neat stuff, electricity is discrete units of charge if you look close enough.  8-)
mixed_signal
Reply #4 - Apr 23rd, 2014, 9:48pm
Hi loose electron,
Honestly speaking it is my dream to have that experience of observing noise from a single electron. I shall definitely try and let you know .
I want to bias a baseband buffer (30MHz) at the end of a receiver. The buffer is a source follower to drive 50 ohm. I want to use attached biasing network. I dont want to use resistive voltage divider because MOS threshold may vary and cause problems in onchip implementation. Do you agree? is my scheme ok?
Reply #5 - Apr 24th, 2014, 4:15pm
should work, but I expect the main source of noise in Vout is the active load (NMOS current source) used in the output amplifier.
Do some noise simulations and determine what your noise source are.
