pcardoso73
Portugal
Hello Andrew,
Thanks for your reply.
I am runing simulations for several tests with ADEXL. As I have to do post-processing of the data, I need to save all the data into .csv files, having a csv per test. As the number of tests is large, I would like to automatize these tasks somehow. Let's say I have tests with names as: test_tran1, test_tran2 ... test_tranN.
Is it possible to generate a script that takes each test and saves the data on a csv, where the name of the file is the same as the name of the test ?
Regarding question 3, I believe it makes no sense because I was trying to do part of the post-processing on ADEXL, instead of using Matlab.
Your answer to question 2 works perfectly. Thanks. Best regards, Pedro
