Jul 17th, 2024, 10:31pm
verilog-A syntax for a capacitor or resistor (Read 3649 times)
bigball
US
Apr 30th, 2014, 6:14pm
Hi:
Does VerilogA have the same syntax as verilog_AMS?
I'd like to add a capacitor and resistor to my verilogA modeling, is the following code correct? By the way, how do I add thermal noise to the resistor?  Thanks.
inout a,b;
electrical a,b;
parameter real r=4K from (0:inf);
parameter real c1=200p from (0:inf);
parameter real c2=6p from (0:inf);
electrical int;
capacitor #(.c(c1)) C1(a, int);
capacitor #(.c(c2)) C2(a, b);
resistor #(.r(r)) R(int, b)
boe
Re: verilog-A syntax for a capacitor or resistor
Reply #1 - May 8th, 2014, 2:05am
bigball wrote on Apr 30th, 2014, 6:14pm:
Hi:
Yes, Verilog-A is a sub-set of Verilog-AMS. Did you try your code? What was the result? The noise modelling functions should be described in the documentation.
- B O E
Reply #2 - Jul 8th, 2014, 7:23am
The syntax you've shown uses the Spice compatibility documented in Annex E of the Verilog-AMS LRM; that means, you are actually adding Spice capacitors and resistor, and the simulator should be including the thermal noise of the resistor, as it would for a resistor in its native netlist format.
You could write your own module for the resistor and use white_noise to add thermal noise.
