Jul 19th, 2024, 10:15pm
Biasing two stage amplifier (Read 2022 times)
anhnha
Earth
May 12th, 2014, 2:58am
Please help me with the question below about two stage amplifier. Thank you.
Frank99
Re: Biasing two stage amplifier
Reply #1 - May 14th, 2014, 2:24pm
the CM upper limit of Vin is limited by the vgd voltage.
when vg1 is raised above the vd1 by a vth1. M1 will go into triode.
and vd1 = vdd-|vth3|
therefore vin - (vdd-|vth3|) < vth1(include body effect)
so vin must be < (vdd-|vth3|) + vth1 for M1 to remain in sat.
what do  you think?
Hrishikesh
Reply #2 - May 15th, 2014, 3:49am
I think it should be vsg3 instead of |vth3|. vsg3 is set by the bias current, I5/2 depending on the W/L of M3.
