Zorro
Dear Designer's Guide Team,
Let's assume that I have a verilogams module where I have to implement some functionality and I can do that either in the digital context or in the analog context. Which approach will simulate faster? I understand that by using verilogams by default the digital and analog kernel will be used by default, so this is where my question arises.
I will try to explain with an example. I want to monitor an analog signal. I can do something like this using only the digital context:
always @( above(V(vdda_v)-(vdda_v_LoRange)) or above((vdda_v_HiRange)-V(vdda_v)) or // vdda_v rises above the low threshold or falls below the high threshold above((vdda_v_LoRange-dv)-V(vdda_v)) or above(V(vdda_v)-(vdda_v_HiRange+dv)) // vdda_v rises above the high threshold or falls below the low threshold ) begin if ( (V(vdda_v)>=vdda_v_LoRange) && (V(vdda_v)<=vdda_v_HiRange) ) begin vdda_v_state = 1'b1; vdda_v_flag = 1'b1; end else begin vdda_v_state = 1'b0; if (vdda_v_flag==1'b1) begin $fstrobe(output_file, "WARNING: V(vdda_v)=%gV is exceeding the defined safety ranges at time=%gus\n", V(vdda_v), $realtime); end end end
I can also write the previous code in a very similar way in the analog context i.e. inside the analog begin... end block.
So, my questions are:
1. If I write my code only in the digital context, will the simulation run faster?
2. If there is no analog begin...end block inside the module, will this make the simulation run faster? Or, by default, because it is a verilogams module both analog and digital engines/kernel will be activated (by default) and there will be no difference in the simulation speed.
3. This question is more related to the approach or the way of writing the code. Which approach would be more recommended in terms of simulation speed? To use, if possible, only the digital context or it does not make any considerable difference?
Regards and thank you for your feedback! Zorro
