Jul 16th, 2024, 4:06pm
Capacitive loading of input probe pad+coax cable+sig gen (Read 2756 times)
mixed_signal
May 24th, 2014, 5:03am
I am using RF probes to introduce 2.4GHz to a matching network (ONCHIP) from a signal generator. I want to know approx. parasitic capacitive loading (paralle C from input to ground) at the input due to signal generator+coax+rF probes. I want to design matching network accordingly to account for this.
Re: Capacitive loading of input probe pad+coax cable+sig gen
Reply #1 - May 26th, 2014, 11:49am
For those frequencies you need to design a 50 ohm terminated cable connection on your board and input port on the IC that is designed to handle that 50 ohm cable signal.
By probe methods? Not with any accuracy.
mixed_signal
Reply #2 - May 26th, 2014, 10:35pm
Hi loose-electron
By probe methods I mean RF probes for probing die (onchip). I have pads on silicon where the probe can be landed. I am worried about the loading of the RF probe? Is it capacitive ? approx. value?
Reply #3 - May 30th, 2014, 3:07pm
probes available for a probe station are pretty well specified relative to their input loads.
Generally I avoid probes to a wafer its just to awkward to do and does not yield good repeatable results.
