Jacki
I see your log file, it seems you have two problems. One is the cellmap, usually the cellmap file is provided by the foundry, you don't need to add it by yourself except the parasitic resistor and capacitor. Second is your grid setting in the layout. Each designkit has its own x,y snap space. when you start to draw the layout, the default snap space is already the minimum one, you cannot change it to a smaller value, or else you have the grid problem. Hope it can help you. Jacki
