mixed_signal
Hi experts,
I have the following requirements for my frequency synthesizer PLL
center frequency= 700MHz, channel bandwidth=300KHz channel switch time<=100us Phase noise<= -100dBc/Hz@ 1MHz offset
I want to make the PLL as low power as possible (<700uW). Which is the most suitable architecture: All digital PLL Integer N PLL (Type 1 or Type2) Fractional N PLL
With type2 integer N PLL: Loop BW=1/10th of channel BW=30KHz. This makes it difficult to achieve channel switch time of <100us
