Jul 16th, 2024, 4:26pm
Choosing PLL: ADPLL or Fractional N or Integer N (Read 2335 times)
mixed_signal
Jun 11th, 2014, 8:37pm
Hi experts,
I have the following requirements for my frequency synthesizer PLL
center frequency= 700MHz, channel bandwidth=300KHz
channel switch time<=100us
Phase noise<= -100dBc/Hz@ 1MHz offset
I want to make the PLL as low power as possible (<700uW). Which is the most suitable architecture:
All digital PLL
Integer N PLL (Type 1 or Type2)
Fractional N PLL
With type2 integer N PLL: Loop BW=1/10th of channel BW=30KHz. This makes it difficult to achieve channel switch time of <100us
hwa_chan
Re: Choosing PLL: ADPLL or Fractional N or Integer N
Reply #1 - Jun 20th, 2014, 8:44am
digital pll
Reply #2 - Jun 20th, 2014, 7:42pm
Your phase noise is the big issue. All digital at that phase noise number? I doubt it.
