martinm_de
Munich
Mixing analog and digital sometimes makes things easier.
E.g. if you have a simple ADC with programmable gain, you put the gain model into the analog part, since it is analog, and you put the gain decoder, which is digital in nature, also into the analog model.
If you have e.g. a pipelined ADC where the digital part collects all the bits from the analog part, it may be required to design the digital part using static timing analysis.
Here, it would be a desaster to mix mix analog and digital, you better separate analog and digital.
Makes it also easier to create a .lib file for the whole block.
