Jul 17th, 2024, 10:28pm
Changing clk period dynamically (Read 1573 times)
satvika
Jun 26th, 2014, 3:28am
I am generating triangular wave using the following code. I am instantiating this in top level module. Is there a way I can change the value of period on the fly, if I need to change from one frequency to another.
module V_triangle_generator(out);
output out;
voltage out;
parameter real period = 10n from [0:inf),
               ampl   = 1;
integer slope;
real offset;
analog
begin
  @(timer(0,period))
  begin
    slope = +1;
    offset = $realtime;
    discontinuity(1);
  @(timer(period/2,period))
  begin
    slope = -1;
    offset = $realtime;
    discontinuity(1);
  V(out) <+ ampl * slope * (4*($realtime-offset)/period - 1);
Thanks in advance
boe
Re: Changing clk period dynamically
Reply #1 - Jun 26th, 2014, 9:17am
Satvika,
my V-AMS documentation states "[p]arameters are constants, so you cannot change the value of a parameter at runtime", so you need to change the definition of the period to a variable.
You will probably need to change the timer() implementation to make sure that no phase jumps can occur.
- B O E
