Jul 18th, 2024, 1:20pm
How to deal with simulation with too many pins? (Read 2498 times)
wayne_luo
Jul 01st, 2014, 8:28pm
Hi everyone,
I have a question when I simulated a simple adder by cadence virtuoso. I've designed a 64-bit adder and would like to make a simulation. But it seems too boring when I do so because there are almost 200 pins. That is to say if I just use vpulse (NCSU_Analog_Parts -> Voltage_Sources -> vpulse) in this process, I need more than 100 voltage sources in my design that will be boring and time consuming. Are there some other kind of sources that can be used in this situation or some other method?
Thanks a lot!
Re: How to deal with simulation with too many pins?
Reply #1 - Jul 1st, 2014, 8:47pm
Use Verilog-AMS for the testbench. Once you use Verilog-AMS for this you will never go back to using a schematic.
wayne_luo
Reply #2 - Jul 1st, 2014, 10:48pm
Thanks for your response, Ken.
I know the Verilog-AMS and it should be a good choice, but I just wonder if I can do this simulation by cadence spectre. Maybe I can extract the netlist of the model from the schematic and simulate it by coding manually. It seems a boring work too.
-Wayne
Reply #3 - Jul 2nd, 2014, 12:55am
You would use AMS Designer. Write a Verilog-AMS testbench and instantiate the schematic. You can then fully exercise the adder with a few lines of code. You can even make the testbench fully self checking.
