Jul 16th, 2024, 2:38pm
Decoupling cap for RF PCB (Read 2967 times)
mixed_signal
Aug 01st, 2014, 9:07am
I have designed a receiver with 2.4GHz LO, 2.42GHz RF and 20MHz baseband. The baseband has a seperate VDD and I want to decouple the 20MHZ in VDD. What kind of capacitors shall I use to decouple 20MHz ? Shall I use electrolytic cap with srf=20MHz? Can anyone suggest a good decoupling strategy?
The baseband has both 20MHz and 2.4GHz component. I can use 20nF for 20MHz and 20F for 2.4 GHz but since they are widely spaced I am concerned about antiresonance issues.
Re: Decoupling cap for RF PCB
Reply #1 - Aug 1st, 2014, 5:37pm
you want a parallel combination of electrolytic for low frequency and ceramic for high frequency.
Research self resonance of capacitors a bit.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ve...
Above is a good basics document
Reply #2 - Aug 3rd, 2014, 5:24pm
Here is a description of how to design a bypassing network: http://www.designers-guide.org/Design/bypassing.pdf
Reply #3 - Aug 4th, 2014, 2:00pm
Understanding the subtle aspects of the different capacitor types, strengths and weaknesses, thermal varinace issues, dielectric issues, ESR, self resonance frequencies of a capacitor, etc, are all useful items to be familiar with.
