AMSA,
AMSA wrote on Aug 14th, 2014, 5:56am:BOE, but that wasn't what I've made? If you notice on the circuit, the feedback is taken after 2 delays, that is, two inverter - so to say after an even number of inverters.
Isn't correct?
Yes, it is. I was referring to your earlier post:
AMSA wrote on Aug 6th, 2014, 5:35am:... If I add only one more delay (3) the wave gets a strange shape. It only works with pairs. Why this happens?
AMSA wrote on Aug 14th, 2014, 5:56am:... However, after I've done my readings, I put that into practice and I found that I canno't create an accurate delay (space between the signals) between the signals in a way that I can do it in a fine manner, that is, have something like a fine tune of the delay.
I've enven tried with only two inverters (even) with small values of W/L, somsthing aroung 200n/160n and even though I didn't managed to get that fine tune of the delay. ...
You can influence the value of the delay chain by sizing and loading.
However, as already mentioned by carlgrace, there are fundamental limits what you can achieve in your process (and under your operating conditions), also in terms of accuracy (variance).
- B O E
