May 2nd, 2024, 8:56pm
Weak pull up/down and keeper in IOs (Read 5589 times)
dewy
Aug 12th, 2014, 6:27am
The block mentioned in the subject is usually used in IOs to pull up/down the pad when it is floating (please correct if this is wrong). Besides these, there is also a keeper mode and I am not sure when that is enabled. Can anyone give me an explanation on when exactly each of  the mode (up/down/keeper) is enabled?
Re: Weak pull up/down and keeper in IOs
Reply #1 - Aug 12th, 2014, 11:48am
Can be unique to the particular device.
Most of the time it means some form of pull up, or pull down (if driver to the pin is tristate it fgoes to that state) or a "keeper" which means that the input is  weakly held in a particular state, such that nothing is connected outside the IC but the pin is kept either high or low.
The details are unique to a device. If you look at a FPGA/CPLD/uController document, these definable states will have explicit definitions. (i.e. "5 uA pull up current is turned on when the I/O is configured in the Keep High mode)
unique to vendor-design
RTFM
