Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 29
th
, 2024, 8:04pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› comparator diff pair
Previous topic
Next topic
comparator diff pair (Read 3644 times)
newic
Aug 19
th
, 2014, 7:23am
hi
For a analog type comparator, shall the diff pair in saturation or linear? If it is in saturation, it causes its size bigger and slow down the speed, where speed is important.
tradeoff between gain vs speed?
IP Logged
aaron_do
Re: comparator diff pair
Reply #1 -
Aug 19
th
, 2014, 7:32am
Perhaps you should clarify what you mean by "analog comparator". Is the output latched? Is the differential pair directly connected to the latch or is it part of the pre-amp?
Aaron
IP Logged
Reply #2 -
Aug 19
th
, 2014, 6:04pm
generally you want the device to function as an amplifier with common mode rejection. Therefor in saturation.
IP Logged
carlgrace
Berkeley, CA
Reply #3 -
Aug 19
th
, 2014, 10:38pm
OP didn't say if the comparator was dynamic of if the diff pair was a pre-amp in front of the latch. Changes the answer.
Unless you know what you're doing though, a linear amplifier in front of the latch is usually a good idea.
IP Logged
newic
Reply #4 -
Aug 24
th
, 2014, 12:45am
got it thx. but it slow down the speed.
IP Logged
analog_rf
Universe
Reply #5 -
Sep 26
th
, 2014, 3:39am
putting input transistors in linear will lessen your resolution(difference between inputs for which output is high).
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
