Jul 16th, 2024, 2:27pm
Water cooling for RF electrode (Read 2684 times)
Asta
Aug 19th, 2014, 8:57am
I would like to ask some information about a the impact of a water cooling system on a RF circuit (13.56MHz, a few kW).
The circuit would look like this:
So, the water would be in contact with the electrode and connects it to ground via a plastic tube. Sadly it will have to be tap water (DI water would solve the problem).
What is unclear to me is if at 13.56 MHz, the water has to be considered mostly as a conductor (with a resistance of 20-200 Ohm/m) or if there are effects similar to the skin effect one would find in a conductor?
More generally, I've searched but couldn't find reliable sources for the impedance of water (with real and imaginary parts) at 13.56 MHz or around and would be happy if anyone knows where to find the info.
So, in the end, is this system just a simple R from the water in parallel to the electrode capacitance or is it more complex?
Thank for the support.
Asta
Re: Water cooling for RF electrode
Reply #1 - Aug 19th, 2014, 1:38pm
characteristics of water changes so  much with the dissolved contents.
there are other fluids used for thermal conduction methods, as well as high volume flow air.
Do you really need a direct contact water system? I know 50KW broadcast transmitters that get away with air and do quite well.
Asta
Reply #2 - Aug 19th, 2014, 11:06pm
Thanks for the suggestion of using air but I doubt that high flow of hot air in the middle of a lab would be fully appreciated. But I'll keep the idea in mind in case water proves too challenging.
And yes water properties (or at least its DC resistance) change a lot, but I'm still quite curious regarding its general RF properties.
Asta
Reply #3 - Aug 20th, 2014, 5:15pm
consider mineral oil if it is a lab setup
