Jul 16th, 2024, 1:45pm
OR Model (Read 2157 times)
bki
OR Model
Aug 22nd, 2014, 4:37am
i have a problem with the VerilogA OR Model. I always get errors.
Can someone help to modify it?
This is the Code:
`include "constants.vams"
`include "disciplines.vams"
module V_or(in,out);
input [0:1] in;
output out;
voltage [0:1] in;
voltage out;
parameter real size = 2 from [2:inf),
               vout_high = 5,
               vout_low = 0 from (-inf:vout_high),
               vth = 1.4,
               tdelay = 1n from [0:inf),
               trise = 1n from [0:inf),
               tfall = 1n from [0:inf);
integer in_state[0:1];
integer out_state;
integer j;
real vout;
genvar i;
analog begin
  @(initial_step) begin
    for(j=0;j<2;j=j+1) begin
    in_state[j]=0;
      for (i=0;i<2;i=i+1) begin
   @(cross(V(in[i]) - vth)) begin
      in_state[i] = V(in[i]) > vth;
   out_state = 0;
        if (in_state[i]) begin
       out_state = 1;
        if (out_state) begin
       vout = vout_high;
           else begin
            vout = vout_low;
Thank you!!!!
boe
Re: OR Model
Reply #1 - Aug 22nd, 2014, 9:55am
bki,
see this post.
Also, please provide codeproperly formatted and enclosed in [ code ] <add your code here> [ /code ] (without the spaces).
- B O E
Re: OR Model
Reply #2 - Aug 22nd, 2014, 10:31am
