bki
i have a problem with the VerilogA OR Model. I always get errors. Can someone help to modify it?
This is the Code:
`include "constants.vams" `include "disciplines.vams"
module V_or(in,out); input [0:1] in; output out; voltage [0:1] in; voltage out;
parameter real size = 2 from [2:inf), vout_high = 5, vout_low = 0 from (-inf:vout_high), vth = 1.4, tdelay = 1n from [0:inf), trise = 1n from [0:inf), tfall = 1n from [0:inf);
integer in_state[0:1]; integer out_state; integer j; real vout; genvar i;
analog begin @(initial_step) begin for(j=0;j<2;j=j+1) begin in_state[j]=0; end end for (i=0;i<2;i=i+1) begin @(cross(V(in[i]) - vth)) begin in_state[i] = V(in[i]) > vth; end end out_state = 0; for(j=0;j<2;j=j+1) begin if (in_state[i]) begin out_state = 1; end
if (out_state) begin vout = vout_high; end
else begin vout = vout_low; end end end
Thank you!!!!
