Jul 16th, 2024, 9:18pm
Boost Converter in Dickson Configuration (Read 1989 times)
bki
Aug 22nd, 2014, 8:06am
i have a Boost Converter in Dickson Configuration to produce negative voltage at the output. (see attached)
Now i realized from the MOSFET technology, that on the drain side 650V maximum are allowed.
So, does it mean the MOSFET will not work for -200V on the drain side ? Simulation doesn´t show any problems.
If it is a problem, is there any trick how i can avoid it?
