aaron_do
since university days I've always wondered about the equation Vp/Vs = Is/Ip (where s and p are secondary and primary). It seems to be only true when ωL >> Rload, so I don't know how it made it into text books.
In answer to your question, assuming k = 1, and Q = ∞, Vs/Vp is determined by the turns ratio. For the current, it completely depends on the loading. You can use knowledge of the voltage across the secondary winding to calculate the current through the other components on the secondary side. Also, the law of conservation of energy will of course apply, so at resonance, the input power will be real, and the power in will equal to the power dissipated in the resistors.
regards, Aaron
