aaron_do
Hi Azadbakht,
are you asking for a RLCK model for a 2nH inductor at 4-6 GHz? I doubt you will find one since the model depends on a lot of factors such as
1) how complex is your model? 2) the process. Height of the metal above the substrate, thickness of the metal, copper or aluminium etc... 3) there are many different ways to design an inductor and depending on the Q you want you will find many different answers.
There are some open-source EM simulation tools you can try out which I think you are allowed to use for educational purposes but you will have to check. Another option is Asitic (just google it). I've never used it but it should be a good starting point.
regards, Aaron
