simsim
I am running pnoise to simulate flicker noise. I add specific points at 10Hz increments for about 4kHz. However, when ADE is run, the simulator seems to truncate the number of points. Much fewer of the points are simulated. Is there a limit in "Add Specific Points" (or the "values" parameter in the text netlist)?
