Jul 16th, 2024, 1:44pm
Magnetic field in the center of an on-chip transformer (Read 2764 times)
Nath
Sep 16th, 2014, 6:53pm
I have a  fundamental question about the magnetic field in the center of an inter-wound symmetric monolithic transformer. As I understand it, the built in phase inversion from the primary to secondary of an inter-wound (lateral) transformer results in ZERO magnetic field at the center.
This is quite contrary to a spiral inductor whose field is strongest in the center. Does this make sense or am I not looking at this correctly?
Nath
Re: Magnetic field in the center of an on-chip transformer
Reply #1 - Sep 17th, 2014, 8:09am
care to provide a picture of what you are talking about?
aaron_do
Reply #2 - Sep 18th, 2014, 4:28am
Hi Nath,
I believe your reasoning is correct. The currents in the primary and secondary will be going in the opposite direction and the magnetic fields which they produce will cancel at the center of the transformer.
Aaron
totowo
SH, PRC
Reply #3 - Nov 13th, 2014, 11:25pm
According to Lenz's law, the secondary current is really trying to cancel the magnetic flux, but it is always more 'weak' to cancel all. Smiley
Nath wrote on Sep 16th, 2014, 6:53pm:
Nath
View Profile totowo totowo   IP Logged
