May 7th, 2024, 12:39am
How does Spectre calculate phase noise? (Read 3897 times)
carl_chao
Sep 26th, 2014, 8:52am
Does Spectre measure the final phase noise like this:
1) Measure the periods (T(i))of the clock waveform, and calculate the average period (T)from it;
2) Cauculate time domain phase noise like this: 2*pi*(T(i)-T)/T;
3) Perform FFT on the time domain phase noise to get the phase noise spectrum.
Carl
carl_chao
Nobody knows or is it too simple a question?
Reply #1 - Oct 24th, 2014, 11:22am
Re: How does Spectre calculate phase noise?
Reply #2 - Oct 24th, 2014, 12:22pm
No, that is not the way SpectreRF computes phase noise. In fact, when you use the phase noise direct plot feature in ADE you are not plotting the phase noise at all, rather you are plotting the normalized noise (the time-averaged noise divided by the signal power). It happens to be an excellent approximation to phase noise when applied to oscillators, but not when applied to non-autonomous circuits
If you want to know how SpecreRF performs noise analysis, take a look at Introduction to RF simulation and its application.
carl_chao
Reply #3 - Oct 30th, 2014, 9:08am
Thank you very much for the reply!  So Spectre calculates both the amplitude and jitter noises in its phase noise analysis.  After the oscillator stablizes, I expect the noise should come mostly from phase noise.  Especially for sampling circuits, is it more suitable to calculate the phase noise in the way as I said in my first post?  No that it's called "phase noise", why doesn't Spectre just consider the phase portion of the noise by extracting the time information at the threshold crossing points (like half supply voltage).  It should be hard for Spectre to do that.
Best,
CZ
Reply #4 - Oct 31st, 2014, 1:42pm
What you suggest is a considerably more expensive and less accurate simulation, and as you point out an oscillators noise is generally dominated by phase noise, so the easiest and fastest thing for the simulator to do is to compute the time-averaged noise and have you, the user, compute the normalized noise and interpret it as phase noise.
Your response was difficult to parse. Please read what you write before you post and make sure you are actually saying what you mean to say.
