Jul 16th, 2024, 1:24pm
mixing spice and VerilogA (Read 4543 times)
jmith
Sep 29th, 2014, 9:10am
I'm looking for a simple example which contains a spice subcircuit and this subcircuit is referenced from a VerilogA model. My question is: how this spice file read from the VerilogA model, through an include file? Or there is no include file and the spice model found in an other way? Or there is a .lib command in the VerilogA model file?
boe
Re: mixing spice and VerilogA
Reply #1 - Sep 30th, 2014, 1:48am
Jmith,
you instantiate the subcircuit in Verilog-A. If it is in the Spice netlist your tool should use it.
- B O E
jmith
Reply #2 - Sep 30th, 2014, 4:24am
From the Verilog-AMS Language Reference Manual
`include "disciplines.va"
`include "constants.va"
module diffPair (c1, b1, e, b2, c2);
 electrical c1, b1, e, b2, c2;
 vertNPN Q1 (c1, b1, e);
 vertNPN Q2 (.c(c2), .b(b2), .e(e));
Where vertNPN is a spice model line. I assume this code is can not compile. How to fix this code?
boe
Reply #3 - Sep 30th, 2014, 9:28am
Jmith,
Quote:
... I assume this code is can not compile.
Why not? The tools I have available compile it.
Of course, it won't simulate unless you give an implementation for vertNPN.
- B O E
jmith
Reply #4 - Sep 30th, 2014, 10:29am
It means in the VerilogA source file not needed to reference any Spice library?
boe
Reply #5 - Oct 1st, 2014, 1:51am
jmith wrote on Sep 30th, 2014, 10:29am:
Verilog-X does not need any definition of sub-cells to compile. Of course, the sub-cells need to be present for the simulation, though.
- B O E
