Jul 16th, 2024, 1:59pm
VCO Design (Read 3751 times)
AZADBAKHT
VCO Design
Oct 17th, 2014, 1:49pm
Hi all
i want to design LC-VCO in 8-12 Ghz (X Band).
so i designed a LC-VCO without switch Capacitor and obtained 3G Kvco in simulation.also i designed this VCO with Switch Capacitor and obtained  250-400 M Kvco in simulation.
now i need to know,can i use this two design in pll!
whats your opinion? can i do it?
thank for your attention.
View Profile milad12333   IP Logged
tm123
Chicago, IL
Re: VCO Design
Reply #1 - Oct 19th, 2014, 8:38am
Hi AZADBAKHT,
High Kvco like this will likely result in high VCO phase noise and high PLL spurs.  Of course it depends on what your specs are but I consider 100MHz/V Kvco as high, so I would look at other design techniques to reduce it.
Tim
raja.cedt
Re: VCO Design
Reply #2 - Oct 19th, 2014, 8:50am
As Tim said it all depends on your phase noise requirements. But in general for serial IO applications 800Mhz/V is okay at least for the all the standards below 8Gbps. Where as in case of wireless people say it's too high.
Higher Kvco increase noise from loop filter(but this is very less compared to VCO,CP noise), this makes your vco very sensitive to power supply noise.
Have a proper estimations for the final jitter/phase noise.
Raj.
AZADBAKHT
Re: VCO Design
Reply #3 - Oct 19th, 2014, 10:10am
ok
Thank a lot sir Tim.
AZADBAKHT
Re: VCO Design
Reply #4 - Oct 19th, 2014, 10:13am
ok
Thank for your attention sir Raj.
