bki
i need a switch that connects 150V to the load. That means, if the switch is closed i have 150V on the drain side and 150V on the source side.
Any idea, how can i realize this switch? Maybe is there a solution available on the market?
As far as i know, the most Power MOSFETs only accept such high voltages only on the drain sides but not on the source sides.
Please help!
