bki
i try to connect -40V charge pump output to the load by use of an Analog Switch. I though of attached idea of implementation in the red box.
The concept with PMOS transistors is perfectly working for a 150V supply, but i have problems with the attached NMOS implementation for -40V.
What can be the problem here?
