Jul 17th, 2024, 11:28am
Analog Switch Problem (Read 2720 times)
bki
Oct 27th, 2014, 8:51am
i try to connect -40V charge pump output to the load by use of an Analog Switch. I though of attached idea of implementation in the red box.
The concept with PMOS transistors is perfectly working for a 150V supply, but i have problems with the attached NMOS implementation for -40V.
What can be the problem here?
Re: Analog Switch Problem
Reply #1 - Oct 28th, 2014, 10:09am
voltages of all nodes and more information about the ttransistors being used are needed
