Jul 19th, 2024, 8:25pm
Linear Regulator test bench (Read 2238 times)
amruta
Oct 28th, 2014, 8:49am
Hello ,
I am trying to write a verilog-AMS code for DC step function which will act as a input to the Linear Regulator. Does anyone have an example code for this?
Thanks.
boe
Re: Linear Regulator test bench
Reply #1 - Oct 29th, 2014, 3:09am
Amruta,
I recommend you use a "transition filter" for this.
- B O E
amruta
Reply #2 - Oct 29th, 2014, 8:06am
Hello BOE,
Thank you.
Do you have any recommendation on how to construct a a piecewise linear source for the input of the regulator? Slew rate is 3V/10US.
Thanks a lot.
boe
Reply #3 - Oct 30th, 2014, 4:59am
Amruta,
you could combine a slew filter and a transition filter: Code:
slew(transition(Vsignal, tdelay, trisefall_min), slew_max)
- B O E
Reply #4 - Oct 30th, 2014, 12:34pm
Wrapping slew around transition is redundant and you should not do it.
To do what you want you need code that looks something like this:
real Vraw;
initial begin
   for (Vraw=1.5; Vraw < 18.5; Vraw = Vraw + 0.5) begin
	 #(10u);
	 fails = abs(V(out) - Vexpected) < 25m;
	 strobe("%s: V(out) = %fV, expected = %fV", fails ? "FAILED" : "Passed", V(out), Vexpected);
analog begin
   V(raw) <+ transition(Vraw, 0, 1u);
amruta
Reply #5 - Oct 31st, 2014, 8:32am
Ken,
I tried your method, but I was not getting the voltage to rise from 0 to 3V. Rather it was staying steady at 3V right from the start. What can I do to ramp this voltage from 0 to 3V with a slew rate of 0.3V/us?
initial begin
for (Vraw = 0; Vraw <2.9;Vraw = Vraw+ 0.3)begin
$strobe("Vraw=%f. \n", Vraw);
#(1u);
analog begin
//V(piecewise_voltage_source)<+(values[i+1] - values[i]) * ($abstime - times[i])/(times[i+1] - times[i]) + values[i];
V(piecewise_voltage_source) <+ transition ( Vraw,0,50u);
V(vsrc)<+V(piecewise_voltage_source);
I(current_in_out) <+ V(vin, vout)/rdson;
x=I(vsrc,vin);
$strobe("x=%f. \n", I(vsrc,vin));
Reply #6 - Oct 31st, 2014, 1:32pm
Your code is quite different from mine. Perhaps if you used my code it would work?
amruta
Reply #7 - Nov 6th, 2014, 10:51am
Ken,
Thank you Smiley. I used your code..it works now.
Regards, Amruta
