yvkrishna
@loose-electron,
differential amplifier is probably the best way to address this, however my CM noise swing is about 4X larger the min. detectable DM signal present.
However I wonder if there exists any passive circuit which can do this job? When I search for this on google I only get Commonmode choke.
I have also tried using a T network (shown in the pic)which offer different impedance for CM and DM picture, even here I am not able to achieve CM bandwidth < DM bandwidth.
looks like there is some fundamental limitation in what I am trying to achieve using passives.
Thanks, yvkrishna
